What are the differences between Pentair SuperFlo VS (342001) and Pentair SuperFlo VST (342002) pumps?
Hien Nguyen
16
Orlando, FL
Please let me know what are the differences between Pentair SuperFlo VS (342001) and Pentair SuperFlo VST (342002) pumps. Thanks for your answers.
ajw22
16,239
Northern NJ
I think they are the same pump functionally. The VST is Pentair's "Trade Grade" dealer brand.
Why are you looking at a Superflo pump isntead of an IntelliFlo pump?
Hien Nguyen
16
Orlando, FL
Thanks for the information. I currently have Hayward AquaPlus controller, and based on my TFP posts reviewing, it seems that Pentair SuperFlo VS (or VST) pump will be much easier to perform an interface connection than the Pentair IntelliFlo pump.
JamesW
18,498
Why not go with Hayward since it would communicate with the Automation if the software revision is at least 2.65.
What is the software revision?
How old is the box?
Hien Nguyen
16
Orlando, FL
My Hayward "Goldline" AquaPlus controller has the following software: 1) Main Software revision 4.20; and 2) Display Software revision 3.12. The pool system has been in operation since October 2011. May I have your suggestions on the Hayward variable speed pump for my pool system. Thanks for your responses.
ajw22
16,239
Northern NJ
You doing a DIY install or having a pool company install it?
Hayward Tristar VS pump...
W3SP3202VSP for DIY with standard warranty
SP32900VSP for pool builder install with extended warranty.
JamesW
18,498
You can get a 1.85 hp model or a 2.7 hp model.
The 1.85 hp model is good for lower flow applications. For higher flow applications, the 2.7 hp is preferable.
Even if the 1.85 hp model could meet the flow requirements at full speed, I recommend the 2.7 hp model if you would ever need to run the 1.85 hp model at more than 2,700 rpm due to the noise.
There are multiple models in both sizes. You will need to check the individual details to see what works best for you.
In my opinion, manufacturers make choosing a product unnecessarily complicated and confusing when they create too many models that are not really different.
Based on your second story solar system, I would probably go with the 2.7 hp model to reduce the noise because the 1.85 hp model would need to run at higher speeds and generate more noise.
Do you have any trouble balancing the flow between the lower and upper panels?
I would think that the lower panels would get most of the flow unless you used a valve to adjust the flow to make it even.
It looks like Hayward has rebates available. Many utilities also have rebates available for switching to a variable speed pump. So, check for any available rebates.
Hien Nguyen
16
Orlando, FL
Thanks for your information, JamesW.
Q. You doing a DIY install or having a pool company install it? I am a DIY person, but I am gathering costs from different pool companies for comparisons.
Q. Do you have any trouble balancing the flow between the lower and upper panels? Yes, my current 2-speed pump has difficulties of pumping the water to the second story solar pool panels at lower speed (1750 rpm). When the pump is running at full speed (3450 rpm), there is no water flowing issue at all; however, monthly electric bill will be much higher. Based on my rough calculations, if the lower speed can be set at ~2,200 rpm, the water flowing issue will disappear.
setsailsoon
2,568
Stuart/FL
H,
Not exactly an answer to your question but here's a data point for you. I have a Jandy 2 speed pump that I converted to a variable speed by changing the motor to a V-Green VS motor. On low speed my 2-speed pump could barely reach the roof and it was only a trickle. The new motor 1.65 hp which is less than the smaller pump/motor combination that James suggested earlier and I have no problem at all running 2850 rpm to the roof for max speed and flow rate is improved from high speed on the old 2-speed pump because I also increased the impeller size. Yours will be optimized better than mine. So your pump should perform better than mine.
I hope this helps
Chris
