Hard to imagine there would be any standard or limitations on the pump size for filling the pool. If water comes out the garden hose, you should be good to go. I think well pumps are typically rated for continuous duty as long as water is flowing. However, depending on the type of well material and the depth, I can see how you might need to shut it off to recharge.
