- Jul 20, 2022
- 1,050
- Vinyl
- Hayward Turbo Cell (T-CELL-5)
I suspect but don't know for sure that the equipment is too close to the side property line. It was stated 10 feet in the codes but it is about 8 feet. It's all on the electrician and pool store at this point. The electrician was OK moving the electric back to meet the 6 feet away from the pool code. I don't know if the pool store guys even thought about the setback for equipment. The cord is about 30 inches so if not they can come back and repipe the filter! Meanwhile next door is using an Intex pool (no problem with that!) and I think an extension cord for the filter. Unfortunately for him it's also GREEN!Glad it’s all set up! I hear you on the electrical inspection stuff. Ha! My reinspection is set for Friday and then if it passes I can backfill and cover up all the bonding. Then they have to come back again.
I also had a similar issue with the location of things for the new pool. Had to move my outlet and add some planks to the deck to fill a bigger gap.
I started in July and im in the same spot as you right now.![]()
Now to figure out what to protect the dogs from those mean pipes!
