WaterGuru - A Test
IceShadow
1,613
Milwaukee, WI
I just got the pool back open Friday and got it working again late Saturday. So far the tests have been within 1 - 1.5 PPM for FC and pH has been on the phenol test, but it's only been a couple of days. Give me another week of testing manually vs the device and I can give a better report.
Now that I'm back open and CYA is back in I really should send water off to the lab for another test. Maybe I'll order that... get my CYA number really dialed in.
dperque
30
Austin, TX
@IceShadow Thanks for all the valuable insight! I just ordered one.
Question - my cover is actually a square cut piece of lueders limestone - is there a world where I can remove the circle top and somehow attach what's left to the underside of my skimmer cover? I'm not sure the square adapter they sell will be much help to me.
markayash
1,535
Marrietta Ga
By the way, I think they may have been inspired by my idea because they sell a square adapter now. :)
My son works at a 3d printing company :) He said they can make about anything but its' not cheap..
I went to work with him Sunday to start and stop a job, somebody ordered a full set of keyboard keys :)
IceShadow
1,613
Milwaukee, WI
The circle top is built in. You'd need to do some sort of adapter. How would you replace your cover if it ever cracked?
IceShadow
1,613
Milwaukee, WI
I just bought a new skimmer cover online (replacement) and then had the CNC guy at work cut a circle for it. :)
Reactions: markayash
IceShadow
1,613
Milwaukee, WI
Weekly manual vs WaterGuru check:
Pretty good. I’m getting my sample from a good 3’ below the surface and the Guru tests water going through the skimmer, so some differences from that are likely expected.
dperque
30
Austin, TX
yeah, it's not the best design, but it's just a square piece of stone and no cracks 6 years in. I can't imagine it would be hard to replace. Looking at it again there's a standard circular hole w/in the skimmer so hopefully this can slide in flush.
IceShadow
1,613
Milwaukee, WI
How do you open it? Can you send photos? What size is it? :)
IceShadow
1,613
Milwaukee, WI
Today’s check. WG is about 1ppm low from my Taylor. I am using expired tests in the Taylor kit but so far I’m getting good results and they’re expired in the past few months so I don’t think that’s affecting it.
gorocket1981
159
Montreal, Canada
Thanks for keeping us posted.
I find this really expensive so I am not sure that I will purchase it because of that. I really like the idea though. I find it interesting. It really simplifies the daily testing and it gives a good idea of what’s going on with the pool.
Thanks for all the info on this thread. I am considering purchasing the waterguru. I was looking at the Sutro, but can't bring myself to justify the high price. Can you tell me if this will fit in a 21 foot round above ground skimmer, or is it strictly for inground pools?
Also, is there an expiration date on the cassettes?
Thanks again for the info.
IceShadow
1,613
Milwaukee, WI
I don't believe the cassettes expire, but once they're in the pool they're only meant to be used for the next 60 days.
You can check with WaterGuru but if it fits over your skimmer it should work, I would think!
Thanks. I asked waterguru and they said as long as my skimmer is 8" it will work. Unfortunately mine measures about 7.25" so I guess I'm outta luck. Unless someone who has one can confirm that a homemade adapter of some sort can be made to work? I know that fabricating one to fit a bigger hole would be easier than trying to fit the device into a smaller hole, but I'm sure it can be done. I don't know why they wouldn't make the waterguru to fit standard size above ground skimmers, but there must be a reason?! It would surely expand their market if they did. As of now it looks like I may have to shell out the money for the sutro if I wanted to go down this road. Unlikely at the present time for me though.
IceShadow
1,613
Milwaukee, WI
Is it possible for someone that has the waterguru to take a precise measurement for me to the points in the attached pic? I am trying to determine if this will fit down into a 7" round skimmer hole. Thanks.
About 8-1/4”. You’d need to figure out some sort of domed adapter I’d think.
Wonder if I can make this work? I know the Guru insert measured about 8-1/4", but maybe I can slit it and make it fit. The other end should fit into my existing skimmer. It's an above ground so if it sticks up it wouldn't matter. As long as the tether on the guru is long enough to reach down into the skimmer basket. Thoughts?
