I though You should have the cover open when slamming to have the sun burn off chloramines?
It’s good to let the pool breathe, yes, but it doesn’t have to be the whole time, especially at night.I though You should have the cover open when slamming to have the sun burn off chloramines?
The sun needs access to the water for a small period each day to help remove the CCs. If you can expose the water for a couple hours that should suffice.So should I be leaving the cover open during the day? I have been keeping it closed as much as possible. I have only seen a very slight improvement since Friday afternoon when I cleaned out main drains. I am again, dumbfounded and out of ideas on why this pool will not clear up.
A few others have found that leaving the cover open makes it go faster if the cover has algae on it.So should I be leaving the cover open during the day? I have been keeping it closed as much as possible. I have only seen a very slight improvement since Friday afternoon when I cleaned out main drains. I am again, dumbfounded and out of ideas on why this pool will not clear up.
I actually replaced all of the sand in the filter a few weeks ago so should be good there.Have you tried the deep clean of the filter?
I am leaving it open longer today - it was open for quite a while last weekend as we did use it just a little. As clean as I have the top of the cover I would assume I would see some residue of algae when I closed it if it had any on it....but, I have been bamboozled a few times this season on other things so nothing surprises me at this point other than I can't get this thing cleared up.A few others have found that leaving the cover open makes it go faster if the cover has algae on it.
OK - at this point I would try adding some DE to the filter per the Pool School article to see if that speeds up cleaning up the cloudiness. Keep an eye on the pressure, backwash and add new DE when you go 25% over the clean PSI. It may be often when you start adding DE, but that's good and means the cloudiness should clean up.I actually replaced all of the sand in the filter a few weeks ago so should be good there.
I did 2 weeks ago or so but, then I saw where until it clears up I don't need to worry about the OCLT.Here’s the guide for that
Have you done an![]()
Add DE to a Sand Filter
A clean pool filter will increase the efficiency of your pool! ... your filter are to backwash it, clean the manifolds and grids, and add new DE.www.google.com
Overnight Chlorine Loss Test yet to give you an idea of where you stand?
I have added DE two times prior to today but, it has been at least a week - am I ok to add after each backwash? I didn't see anything specific about that and wanted to check.OK - at this point I would try adding some DE to the filter per the Pool School article to see if that speeds up cleaning up the cloudiness. Keep an eye on the pressure, backwash and add new DE when you go 25% over the clean PSI. It may be often when you start adding DE, but that's good and means the cloudiness should clean up.
Yep.am I ok to add after each backwash?
You’re well into slam now so it may be useful to do an oclt to see where you stand.I did 2 weeks ago or so but, then I saw where until it clears up I don't need to worry about the OCLT.
