- May 23, 2015
- 25,697
- Plaster
- Pentair Intellichlor IC-60
Sounds like you guys got the “extra” special kitchen plumbing install. I only have one cold water line that is untreated water. However, even if I did put an RO faucet in (it’s doable but would require me moving around a bunch of stuff), I don’t think it matter’s much if the input water is soft or not. Both calcium and sodium will be rejected by the RO membrane and the calcium levels, as well as TDS, are still low enough to avoid scaling problems. My biggest issue is the waste fraction being so high (4 gallons of input to create 1 gallon of RO water) that I would opt for the higher cost system that includes a permeate pump to improve efficiency. I often look at the RO units that they sell in the big-box stores and few, if any of them, offer systems with a permeate pump. Then again, drinking RO water is not high on my priority list so the thoughts are mostly academic anyway....
