- May 23, 2015
- 25,698
- Plaster
- Pentair Intellichlor IC-60
I was skimming the thread and wanted to ask you how your tap PH is? My first house we had the culligan had great soft water, but over the years I had to replace many of my shower valves and other fixtures the ph must have been acidic. In my new house we once again added a water softener but went with fleck valves and have a 3 tank system, softener, neutralizer (to neutralize any acidity) and a whole house carbon filter.
My tap water is Tucson city water which is ok. TA is about 100-120ppm, CH is anywhere from 180ppm to 250+ ppm (depends on the time of year) and the pH is 7.6-7.8. Water is always warm. Even in the dead of winter the “cold” water is around 55-60F and can get as high as 78F out of the tap. Heaters don’t need a lot of gas around here to heat water. And if you install a roof top solar heater for your water tank, they barely use any gas at all.
