Water Loss
Skyles32
3
Lexington Ky
Have a new build.
Pool builders are terrible. That being said I have tiny little bubbles barely visible from jets. In addition some bubbles in the pump, leaking on supply side of plumbing on pad. The pipe coming out the pump has a small leak.
It’s a SWG pool 14x28.
With pool leaks are they normally substantial?
This is likely from your SWCG...
Do you have a vsp? What RPM are you running. A VSP, running at low speed, it is normal to have some air in the pot. Mine gets to a silver dollar size and I have it programmed to run on high once a day to clear it.
This is NO BUENO. Have them come out and fix it. You should not have leaks. None!
Reactions: 1poolman1
