It says you checked fc 4 days ago.
Fresh fc,cc, & ph #’s would be more informative.
You definitely need to do an
Overnight Chlorine Loss Test as mentioned above.
If you fail a
SLAM Process w/ liquid chlorine is in order.
After completing that you should raise your cya to about 70 so you’re swg can keep up without the sun eating all the chlorine. Also your salt seems a little low - most intex swg’s prefer around 2800-2900ppm. Just don’t go higher or it’ll throw the high salt alarm
at u.
You can share your pool math logs with us by toggling on sharing in the settings menu
