Water line size and pressure and RO fill line
haroldo
10
Salinas, CA
City water or well?
Test your fill water for pH, TA and CH. Post the results here.
As Mike indicates, 500 ppm CH in fill water is very high.
Also, what capacity is your water softener?
The pool must get a continuous flow of water during the fill process. A water softener has a certain number of gallons of soft water before it needs to be regenerated - so you will run out of soft water before the pool is full.
A 3/4" line to the autofull will be sufficient. Be sure it is plumbed to your water softener so you will be replacing evaporated water with softened water to minimize CH increases to the pool water.
Thanks for the input. The water softener is a fancy one, the Kinetico XP:
It costs about 7 grand, and it never stops providing soft water, as each channel (left and right) regenerate separetely, so when one is regening, the other one is still providing water.
I tested the water with test strips. I tested both the soft and hard water like 5 times each, and the tests results were consistent. The soft water had no hardness at all (at least not detected), the hard water was at the last color of 450+ ppm.
The water is municipal water.
I purchased a Taylor kit, will test the fill water shortly and post.
I spoke with Ken directly, one of the owners of that company. They build them to order, with 5-6 weeks lead time. Cost starts at 6K. This particular model is made for pool fill lines:
As mentioned, test strips are highly inaccurate. Get yourself a TFP recommended test kit and get an accurate reading on tap water CH. You'll likely find that your level is lower than you believe. You could probably fill your pool with unsoftened tap water and maintain that CH level by connecting your fill line for top offs to your softened source. You shouldn't need a high-dollar RO system unless you really need to separate some cash from your wallet.
Test Kits Compared
I’m having a little trouble accepting that price for what it does. “Starting at $6k” I assume gets you 400 GPD. I can buy a fancy marine desalinator for $3.5k at 440 GPD that, as far as I can tell, achieves the same thing with the same basic parts and pieces. Food for thought.
Which fill system are you looking at? Mine is plumbed in 3/4” but it regulates through a toilet fill valve that effectively chokes it down to ~1/4”, so I don’t feel like the supply line size is particularly critical.
