- Dec 16, 2024
- 7
- Plaster
- CircuPool Edge-40
Hello, first time pool owner here (came with a house we just moved into) and have been learning as much as I can from the great people in this forum! Already ordered a TF-PRO kit to start practicing some chemistry.
Attached is an overall picture of the pool, showing the attached spa. It overflows into the main pool. In the mornings the water level in the spa is low, about 1' below the overflow level. It won't let me attach more than one picture, so here is a link: Pool, spa morning level 12-18-24.jpeg
When the pump is running (using the default Pentair VST schedule) the spa level is normal. Water level in the main pool is about 1/3 up the skimmer.
Can anyone explain why the water level is low when the pump isn't running? Where is the water going? I hope it's not a leak.
Here are some more pictures that may help:
Pool plumbing, labelled: Pool plumbing, labelled, resized.jpeg
Check valve 1: Pool, check valve 1, resized.jpeg
Check valve 2 and Valve 2: Pool, check valve 2, resized.jpeg
Valve 1: Pool, return valve 1, resized.jpeg
Valve 3 and 4: Pool, valve 3, resized.jpeg
