Ok here's the latest:
- 6am: added 0.75 gallons of MA
- 7am: added ~4lb of CYA via nylon socks @ 2 returns. Socks were empty in <1 hr.
- 10am: pH tested to ~7.2 (down from 8+). CYA tested too, but shows only a small improvement above 0 right now. I understand that takes time to show up. Then added 3 gallons of 12.5% liquid chlorine spread across the pool.
Marty thanks for the OS Job Lot recommendation - they had a lot of liquid chlorine on hand.
Next step is to brush the walls/floor of whole pool a little later this morning, and then test FC every ~2 hours to see if I need to add more to keep it at 12. How long does it take after adding chlorine to register an accurate reading on the TFT test?
