I'm in the middle of a water exchange due to high CYA. Heated pool to 90 degrees to make sure I've got enough of a split in temperature. Have the new water on the floor in the 8 foot deep end and a submersible pump on the second step in the shallow. Cut the fresh water down to match the pump (pool cover pump) speed @212 gallons/hr. Exchanging approx 13k gallons comes to about 62 hours which is a ridiculous amount of time even though homeowners are away and pool isn't being used. I would like to switch out the pump to something twice if not more fast as long as the fresh water has the volume to keep up.
Can I do this if I'm careful not to upset the water and continue on with my better faster option ??
Thanks in advance,
Allan
Thanks in advance,
Allan
