Hi All
Seeking advice
I have a render lift occurring at the bottom of the pool (around size of a dinner plate) which has taken on water - squishy when I step on it
Something to worry about / repair or just ignore
Concreate pool with Qartzon (or equivalent render finish
Background
I have drained the pool and had a pro come in to repair a rust spot on the wall - totally unrelated to this issue
while the pool is empty i noticed what i would call a wet spider web look on my pool render floor
Upon investigation it appears slightly lifted a tad bouncy and wet - like if i walk on it it squishes and makes a squish sound
There are a few other minor render issues (peels) that pool guy suggested not to worry about - stated "render is just a pretty covering and will eventually wear away . render is not water sealed and always takes on water gets eaten away by chemicals
I have the materials to crack way the render in this spot and patch it but seeking advice on weather i do it or leave it
Chip it away and patch it
leave it
other options open the floor to the experts
The main thing is if i leave it will it cause other issues / damage the pools core / shell / cause the issue to spread
Pool currently empty waiting for wall repair to cure
Seeking advice
Background
leave it
