I have SWG 28,000 gallon liner pool. I’m having difficulty getting my alkalinity within normal range.
Current readings:
PH 7.0
Alk 100
FC 4
CYA 60-70
I’ve lowered my PH to 7.0 from > 8.0 and have lowered my Alkalinity from a high of 160 to a current 100. At the 9th drop of R-009, the water turns purple but at the 10th drop it definitely goes to red. What can I do to lower alkalinity even more? Also, when should I increase my PH? After alkalinity is at recommended level? I plan on increasing PH with aeration or would you recommend using an increaser?
I use an intellichlor I40 which is now set on 20%. Soon, I’m sure I’ll have to increase the %.
Current readings:
PH 7.0
Alk 100
FC 4
CYA 60-70
