Merged posts to single thread - TFP Mod
So after you raise chlorine level after a vomit episode up to just below the slam level...how long do you maintain that level....couple hours or just until your combined chlorines are 0This is where you are going to LOVE knowing us here at TFP! In case of yuckies in the pool you will get *it* out if possible. All people out as well. You will turn your pump on high and test the FC. You will then add enough chlorine to push your FC to just under SLAM level for you CYA as seen in this chart: Trouble Free Pool With you having kids I would print this one out and keep it with your testing box so you don't have to stop and find it on line. Wait 30 or so mins then test again to make sure it is about the same FC levels and turn them loose!
Kim
