Strawberryshortcake
422
Hot Springs, Ar
CircuPool Core-55
I ran the full arsenal of tests after getting my SWG installed and everything seemed good except CSI. According to TFP it's -(negative)1.50, and it says it should be -0.60-0.60. Do I need to get this adjusted?
Results are a few days old. FC is up as is water temp now.
FC 3
CC 0
PH 7.2
TA 40
CH 100
CYA 50
Salt 3650
Temp 79
CSI -1.50
My TA and PH are technically low, but that's just how it's always been. The PH is extremely stable, I rarely had to adjust it and if I do it's because it went down.
Only matters if you have high CH, high TA fill water, and rising pH. None of those things apply to you from your post.
