1. I wouldn't do any experimenting yet without Kim, pooldv, or someone else experienced. I don't think it's a bad thing that you haven't had to add more chemicals than you have. I have a lot more learning to do. I'll help with what I can (how to add chems, etc). But I want others to help you with targets.
2. Did you get your CSI level from Pool Math (are you using the app or the website Pool Math)? That's something I can help with if you need it.
3. Have you printed out or written down these charts? Use them to see what you think your targets should be and verify with someone on here.
Pool School - Chlorine / CYA Chart
4. Your TA might be fine according to the charts. You check and then verify on here.
5. To answer your question: "is it possible that I add the MA and my PH remains really low ?" Let me see if I understand the question. You're concerned that if you lower the TA with the MA, your pH might remain too low? If I understood correctly, the answer is no.
To lower the TA, you do add MA which also lowerw the pH. But it's not permanent. To raise the pH back up without raising the TA, you then aerate (with water falls, spa spillway flowing, etc) The pH will go back up, but not the TA.
Your FC looks good to me, but you check the charts and see what you think.
If you have more questions, let us know. I'll answer what I can, and leave the rest to others. You really don't seem to have a problem.
Mama Suz
