Those lights look great! Do you have any more pictures of your water and interior during the day? My plaster is scheduled for one week from today. I'm pretty much set on my interior, but I keep second guessing myself. ha ha....
Will, why do you want the spillway off sometimes when the pool pump is on and circulating the pool? Is it too loud? My spillway is always flowing when the pool pump is on. That's worked fine for me, because I don't want the spa water sitting still anymore than it already does when the pool pump is off. I have 2 speeds, high and low. When I have friends in the pool visiting, sometimes I will make sure the pump is on low speed, so the noise doesn't get in the way of my old lady hearing. You have a variable speed pump, so doesn't that let you change it to all sorts of speeds including and between high and low?
I'm asking so I can look into changing my routine if the spillway shouldn't be flowing so much.
I have some pictures a few pages back of the finish but when I go home on my lunch to brush the pool I will take some more for you. If there is a certain angle your looking for or something specific just let me know
Thanks - I don't what I'm looking for specifically.. I guess I'm trying to get an idea of how the beads and shells look up close. I'm leaning towards having my plaster guys use double beads and double shells, but I don't exactly know what that means because they don't specify how many batches are needed for my pool so I don't know the total lbs of beads and shells.
Thanks! I'm doing an owner/builder, so I guess that I'm the PB.. The plaster company doesn't t seem to want to tell me how many total pounds of beads and shells, just how many pounds per batch.. If I know how many batches it would take for my pool then I could easily figure the total # of lbs, but for some reason that info is hard to get. Also, if I could figure out how many sqft one batch of pebble sheen covers that I could do the math, but I can't find this info either..
I'm probably overthinking this, as I have done almost every step of the way...![]()
Wow it looks stunning! The lights and everything. So happy for you guys Will!!
What are the dimensions of your pool. I see your perimeter is 95. My pool took 8-9 batches, how many pounds did they tell you they add per batch?
I was not expecting this shade but I'm VERY happy with it, I prefer darker but my wife doesn't but because it's so shiny it looks lighter and she is happyWow. That bling! Is that mostly the shells or is it also the glass beads? I'm also surprised at how dark the finish came out. Were you expecting that shade?
I would guess you pool would need 5-6 batches. Mine is 18k gallons and we used 8 and mine is 7ft deep which means more surface area.My pool is a freeform shape, 95 linear foot perimeter with depth from 3.5-5 feet and a tanning shelf. I think it's about 850 sqft of interior surface area and around 10-11k gallons.
Your latest pictures look amazing - That's a lot of sparkle!!
Thanks - It helps to know that they used 8 batches for your pool. The std upgrade for beads is 50lbs per patch and I'm thinking about doubling it to 100 lbs per batch. I'm not sure how many lbs of shells they use per batch but I'm trying to find out.
