Let me hook it back up and turn the valve and see if water will move through the return.
Ok I hooked it up and water was coming out of the bottom of it by the plug. I had everything tight. Could be an old O-ring or simply a crack. I went to the middle of the return when the valve was open and water was still not coming out. Maybe this is because it was leaking at the plug?
So the middle line going to the booster pump has the valve turned to close. I left it like this all winter last year. Do you think it’s safe to keep it closed when it freezes? Of course the pool will be running when it freezes but just want to be sure. We no longer use the booster pump. Would love to eventually get rid of it and use the middle return from it.
You have a union on the return line after the pool. You could rebuild the return side to pipe the output to the 3 returns.
Let's start from the beginning. The polaris pump is there, as you likely know, to power a a pressure side cleaner.
Polaris booster pumps have a 3/4" Female thread in the pump body. The connector barbs are threaded into the pump, then the hose is put over the barb and secured with a nut.
No VSP is going to have 3/4" connectors, so the answer to your "plug what I have into a vsp?" is no.
As to doable, sure, if you have some PVC skills.
Smart? The polaris pump moves a fraction of the volume of the main pump, there is not competition. If you put a VSP in there, it could end up pulling more volume than your main pump, no bueno. There is no need for a second pump.
Do you have any PVC experience? It might be best to just have a local pool service, or plumber remove the red handled valve, the soft lines, the pump, and just plumb from the T in the vertical line to the polaris pressure line coming out of the ground.
Sorry if I wasn’t clear in the last message. I was meaning to say would it be easy to replace the single speed pentair pump with a variable speed based on the picture I provided?
You will want to find a VSP that has the same input height, and output offset and height from the input...and you will need a pentair pump to re-use the unions, pentair unions are proprietary...I don't know a match off the top of my head...
this is your pump...
Pentair Superflo VST is the closest. The only dimension off is input height...7.58 to 7.71...or .13" higher. This is a medium head pump...not a high head pump...
Do you know if your pump is wired 115 or 230V? Look at the breaker for the pump...if single breaker, then 115, if dual breaker, 230...this matters for the VSPs you can run without re-wiring.
