- Oct 25, 2015
- 5,187
- Plaster
- CircuPool RJ-60 Plus
Folks,
I'm over the hump with recovery from my lightning strike and gas heater frustration. Everything's working great. I even figured out how to start the pool lights at sunset instead of having to adjust the start timer. My next project was to install a Pentair VS pump but my unplanned lightning strike and heaters have me looking to save some up front $ without losing value. I can replace my energy hog single speed pump motor with a VS motor with a payout of about a year. To get maximum savings I plan to control so that it only runs at high speed (probably around 3000 rpm) when the solar heat valve is open. The rest of the time the pump is on I'd just run it fast enough for the pool heater and chlorinator. This would be easy if I used the Pentair pump with my Intellicenter automation. The V-green pump has a connection for the RS-485 bus but I doubt the protocol is the same as Pentair. Each control manufacturer seems to have little differences in their protocols that make it a little harder to use other brand's equipment. I've read the manuals available and the following seems to be workable. Can anybody that has more knowledge than me verify this is correct or let me know if there's an easier way?:
Chris
- The V-green seems to have anticipated this issue so they also have digital inputs that can drive the pump to different speeds. If there's no digital input the pump simply returns to the preprogrammed speed.
- The digital inputs seem to be capable of using a wide range of low voltage signals.
- Seem's like I can put a simple relay that provides 24 vac to the "step 1" digital input when the "call for heat" signal is generated by my Hayward Goldline solar control. Here's an excerpt from the manual that shows a simplified circuit diagram:
- Or can I accomplish the same thing by bringing solar control into the Intellicenter and retire the old Hayward Control?
Chris
