Just joined the TFP forum and I'm pretty excited about all the useful info. Up until now, I'd paid someone to maintained our pool. Now I'm starting anew and doing the maintenance myself. My question is regarding my UV and SWG combo. But first, my goal was to try and have a clean and clear pool while cutting down on the amount of chlorine my family was swimming in. I'd originally installed a Delta E46 UV system and switched the SWG to the OFF position, and only used smaller amounts of liquid chlorine because all the wonderful literature I'd read about UV systems said I could let the UV handle the bulk of my sanitizing and thus, use lower chlorine levels. (I used liquid, for I was told by several other sources than running a SWG on super low wasn't going to give a consistent result.) While this UV/lower chlorine level combo may work for other pools, it wasn't working for me. We live in Valencia Ca, surrounded by lots of trees and it gets windy up here. My pool often has a TON on leaves and debris on it each day that keeps me busy daily, alongside paying someone else to do it weekly. I found that in the summer I had to keep my chlorine levels(using liquid) around 3ppm with the UV and still, it was a battle. I use a flow meter and the math tells me that I'm getting about 2.5 turnovers per day, running a variable speed pump at 1750rpm for 14 hours, followed by 2 hours at 3500 rpm to skim the top. The UV unit feels like a waste of money at this point.
I'm about to cut down and trim some trees around the pool to try and help with the maintenance, and then I'm gonna partially or fully drain it because my cyanuric acid levels are 160 due to my pool guy using conditioner. Here's the meat of my question: In the name of convenience and since my pool is already plumbed for it, I'm thinking of switching the SWG back on. I have no idea how old it is, however. I've lived in the house for 2 years and, as far as I know, it was working up to the point that I turned it off. Valencia has some of the hardest water in Los Angeles, and my pool's calcium reading is 520. Would it be worth it to attempt to clean the SWG w/acid and see if it still has life left? Or just buy a new one?
I'm gonna have many other questions as I step forward into learning how to do all this myself, but for now, I'll leave it there.
