RoyR
Interesting, I have a huge spillover, runs 10 hours per day, and I only have to add a bit of acid (31%) every second day...I’d start with leaving TA low, let the ph creep to 7.8 and see what happens.
So let me ask, how would I want to change it? Currently the water leaves the filter and some goes to the spa and the rest returns to the pool. If i make it pool only the spa water wont be circulated.Pretty good YouTube on how to adjust the cam stop. It is really easy.
How low is your Alkalinity?Interesting, I have a huge spillover, runs 10 hours per day, and I only have to add a bit of acid (31%) every second day...I’d start with leaving TA low, let the ph creep to 7.8 and see what happens.
You would set up a Feature Circuit for Spillway. Schedule it to run for 30 minutes twice a day. The Feature will move your actuated valve from pool return to spa return. The actuated valve for suction would remain from the pool. That will then run the Spillway for enough time each day (which you can adjust if you see an issue) to chlorinate the spa water.So let me ask, how would I want to change it? Currently the water leaves the filter and some goes to the spa and the rest returns to the pool. If i make it pool only the spa water wont be circulated.
How about the freeze protection in winter? Right now water will flow through all the pipes while in freezing temperatures. I do not winterize.You would set up a Feature Circuit for Spillway. Schedule it to run for 30 minutes twice a day. The Feature will move your actuated valve from pool return to spa return. The actuated valve for suction would remain from the pool. That will then run the Spillway for enough time each day (which you can adjust if you see an issue) to chlorinate the spa water.
I went out and looked at my control panel and it does have a spillway button and I pushed it and its like its inactive.... I will research further... thanks so muchI am not familiar with that automation system. If you have any documentation, look for Spillway or Spillover. Most automation systems have it so you can program it.
Are you guys sure the liquid chlorine is not causing my PH to spike? Yesterday I added 3/4 gallon acid because PH was 7.8, Alkalinity was 80. At midnight i added 1 gallon of chlorine and PH is 7.8, Alkalinity 75 today.
So I am using 14% acid. Usually add acid during the day Noon time, then add chlorine at midnight, then check levels at 11am - 1pm, and add again.What % acid are you using?
Test and adjust pH before you add chlorine. Chlorine slightly raise pH when you add it and then lowers pH when it sanitizes. Net effect is pH neutral. If you test pH after you add chlorine you are only seeing one side of the process.
I went to home depot and lowes yesterday and neither place had 31.45 acid. Looked in paint dept, and outdoor area where they keep the pool supplies. I wound up buying 4 cases of 14%.It feels like a lot of acid when you use half strength acid. If you could get 31.45% acid you would be adding about 3/8 a gallon and it would not feel like so much.
Getting your spillover under control will reduce your pH rise and acid needs.
Now that the Alkalinity is down to 70, the Ph is not rising as fast. It went from 7.2 to 7.7 in 3 days. I run the pumps 4 hours day, and 4 hours night.
