Sig,
Does your friend have Solar or not???
There is only one water temp sensor.. It is normally in the plumbing near the pump output or filter input.. When in the Pool mode, it measure the pool water temp and when in the Spa mode it measure the Spa water temp.. All three sensors are interchangeable.
What happened to your friends water sensor???
I am so sorry for the delay. Health issues I won't bore you with.
No, he does not have solar.
I was unsure if the solar input on the various Intellitouch panels would support a temperature sensor input that could be used to measure the pool temperature.
Yes, I realize that the sensors are all interchangeable. The installer used the pool input as the input for his spa temperature which is separate from his pool. The same installer did our pool and spa and after reading some literature, realized that our best option was the Intellitouch 10 which I got the installer to swap out with the original I8 he first installed.
Simply put, he has no way to measure the pool temperature via the panel and correlating smartphone/computer interface. He gets phantom readings and sometime it even reads the same temp as the spa, ~98 degrees. I had gone over and eliminated the wireless link connected to his screenlogic adapter since his wireless was flaky like mine used to be (sometimes it would not connect) until I ran cat6 to the panel and mounted the screenlogic interface adapter inside the pentair panel.
So, in summary, if the solar input can be used to measure his pool temp, please let me know. I am familiar with setting up circuits on the Intellitouch panels but was unsure if a circuit could be setup that used the solar temp input to measure his pool temp.
Thanks for the speedy reply and again, sorry for the delay.
Sig
