- Sep 22, 2011
- 204
I have vinyl liner that is getting replaced in the spring. It has a fairly substantial leak. For example, about two weeks ago, we were expecting snow. I have a mesh safety cover and I read that you should keep the water within 12" of the deck so that snow will not overly stress the cover. I filled it up to about 10" below the deck. Today, when I pulled the cover back, it was about two feet below the deck, so it lost over a foot in about two weeks. I'm not sure why it is leaking so much because over the summer, I didn't even realize it was leaking. It was only after I noticed it was losing water after it was closed that I realized I had a leak.
Anyway, earlier today I had the corner of the cover pulled back so I figured I would shovel some snow from the deck into the pool, since I needed to add water anyway. In shoveling the snow, I kind of threw a shovel full into the corner and the liner busted. The rip is above the current water level, but only by about an inch. That means I will not be able to put anymore water in it and we are expected 4" to 6" of snow in two days.
My wife suggested just taking the cover off, since we cannot fill up the pool enough to protect the cover. Is that an option? Should I just leave the cover on? The water is probably about two feet below the deck.
Thanks.
Thanks.
