I came to the forum to ask about water that seeps through the winter cover which becomes a PIA to drain in spring - usually taking a third of the pool volume with it which results in needing to add high TA well water and me fighting pH for half the summer. First thread I saw was NO cover over the winter. I also use a leaf net - pool probably will freeze for the season sometime in December. Ice won't clear until late April usually. If i keep the leaf net on to catch the errant leaves that blow around until we get snow cover (possibly emptying once the oak tree is bare), adding some liquid chlorine here and there while water is fluid, am I likely to have a clean (ish) pool in May? Last year when i took the cover off, the water was crystal clear, almost no work.
Oh - we do have pine trees about 50 feet up wind of the pool, hence leaving leaf net on.
