- Jul 24, 2020
- 384
- Vinyl
- CircuPool RJ-60 Plus
I am in the process of accessing my equipment needs to upgrade my pump and filter. Last year I added the SWCG to the system and now I would like to changed from a 1HP Hayward Super Pump to the 1.65 HP Hayward Super Pump VS, and with the change to a variable speed pump, I would like to also change out the DE filter for a cartridge filter.
I have a limiting factor of 1.5" suction and discharge piping. I have two skimmers, one bottom drain, which flow thru one single pipe to the pump, and one single discharge pipe that "Ts" off to three returns. total piping is about 109' with ten 90 degree fittings and three "T" fittings.
I have used the INYO pools formula to estimate the TDH of my system currently. With the TDH at 40' the pump flow (SP2607x10) is approximately 77 GPM, this calculates to a velocity of about 14' per second.
I'm a little confused when I look at the Hayward Super Pump VS flow chart, I know that as the speed of the pump is reduced, flow also drops and so does TDH. My question is this a good replacement for my single speed 1HP Super Pump?
I believe as the pump speed is reduced and the flow drops, the TDH is also dropping and I will have flow at all speeds, but I think I want someone smarter than me to confirm that fact.
The next question is on filters. According to flow ratings, the Hayward W3C1200, has 120' of filtration area, and a flow rate of 120 GPM so it would suffice, but from what I have read, when filtering, bigger is better. My current 40' DE filter, the powder charge lasts almost the entire swimming season (I use a robot pool cleaner once a week and I have no trees near the pool), and my pool is very clean. I could bump up to a 325' , 425' or 525' filter, but each one comes at a $ increase. So if I upsize the filter, is 325' enough or should I go bigger 425' or 525'?
