Hello everyone! New here and a new pool owner. We just bought our home about 2 weeks ago and it came with a lovely salt water pool.
I'm learning as I go with regards to the maintenance and chemicals required to balance it. We have a Hayward AquaRite system. When we first moved in 2 weeks ago, our meter said it was at 3200 ppm of salt. After getting our water tested, it had really high levels of free chlorine and high pH. Since the levels of chlorine were so high, I turned down the salt generator from 60% to 30%. We got the pH under control and the chlorine, but then my salt meter said it was at 3500 ppm - even though the test at the store said it was 3100ppm. I turned the whole generator off for a few days (I didn't know what I was doing and stupidly thought it would help the salt levels go down but I know now that's not going to help that), and got my water tested again today and the salt is at 3800ppm (the generator still says 3500 ppm). So on 11/7, according to the store my salt was at 3100 ppm, and today on 11/14 the store says it's 3800 ppm.
I guess my question is - why would my salt level keep going up if I didn't actually add any salt to my pool? The weather is warm, but not enough to lose a ton of water to evaporation. Did I mess something up by turning off the chlorine generator? (FWIW, the chlorine is high again my sample today - so IDK how that would happen if it's been off completely for a few days?).
Should I chalk this up to a potentially bad water sample and just try again tomorrow? The pool store is telling me I need to rent a pump and drain some of the water out, but I'd rather fix whatever caused this to happen in the first place. I don't want to drain the pool and refill it and then this keep happening.
Thanks in advance!
-Heather
Thanks in advance!
-Heather
