First off sorry if this is a dumb thread I decided to join because I would love some advice…
This is my first year with above ground pool 4000 gallons maybe, Steel Pro Max 15 x 42 pool for my son and I am being tested by the pool God’s! My test strips are showing same results almost always, I’ve tried shocking, scrubbing and shocking, swapped to the intex 633t krystal clear pump because the factory pump was not cutting it. Still the pool is cloudy. When I clean the filter, it’s covered in thick sort of, “grey” mucus type stuff, and the filter cartridge housing will have grey particles floating in it when I open it to clean filter. Filter will be completely covered in grey stuff after running pump for 8 hours, clean it, repeat. Same results. I’m using the floating things with chlorine tablets for chlorine, I’ve done my scale build up products, algae protector, etc….
Also I have attached photo of test strips, and the reply I got from the number on the test strip kit where you can send your test kit photo for advice. Any help appreciated!!!!
