I recently purchased a house with a pool outside Houston, TX. The pool is 22,000 gallons with pebbletech.
Before having time to start learning I have been using Leslie’s to test my water and buying chemical to their recommendation.
I found TFP through Reddit and downloaded the app but when I put in the same pool details the suggested ranges are different and I want to double check I haven’t made any errors:
My pool:
22,000 gallons
Pebbletech surface
85f water temp
TFP
FC: 5.0 - 9.0
PH: 7.2 - 8.0
TA: 50 - 90
CYA: 30 - 60
CH: 250 - 650
Leslie’s
FC: 1.0 - 4.0
PH: 7.2 - 7.8
TA: 80 - 120
CYA: 30 - 100
CH: 200 - 400
My pool:
22,000 gallons
Pebbletech surface
85f water temp
TFP
FC: 5.0 - 9.0
PH: 7.2 - 8.0
TA: 50 - 90
CYA: 30 - 60
CH: 250 - 650
Leslie’s
FC: 1.0 - 4.0
PH: 7.2 - 7.8
TA: 80 - 120
CYA: 30 - 100
CH: 200 - 400
