I have a new fancy pool but I have to add liquid chlorine each week. Been active for 3 months but pool builder had maintained previously. I want to understand my system and do it myself, Picture is attached and signature should have equipment details.
Here's my story....
(1.) When I first took it over pool supply store said 0FC but pool was sparkling clear and seemingly perfect. I start adding liquid chlorine to get 3-5ppm. Saly is 3400
(2.) Pool installer says phosphates must be high given no screen and lots of landscaping around but they did not measure. Also they are looking at the fact that the IC40 is running 12 hrs at 80% and believe its ample for the pool for some reason.
(3.) Pool supply store says they read 200ppb or less phosphates.
(4.) pool installer says thats impossible, adds phosphate remover at dosage recommended for high phosphate and instructs me to clean all filters then shock with (4) 1b bags of dichlor.
(5.) I do that and when I try to read FCL with my cheap $20 test kit cant discren so I order K2006C and phosphate kit from taylor.
(6.) Kit comes 2 days after I add the shock and I am able to check everything...FCL 10ppm, CC0ppm, PH 7.6, Totalk 90, CYA 100 Phosphate might be 0 but there is a slight blue tinge...I would say less than 50ppb for sure.
(7.) I turn IC40 to 0% at 8pm 2 nights ago and run pump with salt off and next morning FC still 10ppm.
(8.) Leaving IC40 OFF I run it half of the day and check FCL and its now at 8.6ppm.
Questions....
The cell seemed to not keep up when I took pool care over I had to supplement. My plan is turn cell of tomorrow and measure a few times until it gets to 6-7ppm and see if I reactivate at normal schedule I can get it to hold. However by my math the cell should resupplying 2.25ppm a day (assuming flow doesnt matter) and that might be too little.
-Is it undersized?
-What is best way to know?
-Flow on my VSF matter so long as its above 30gpm?
The VSF is running at 2500RPM for 12 hrs and cell is at 80%
Here's my story....
Questions....
-Is it undersized?
