I just started a pool build a couple weeks ago. 54” flat bottom steel wall liner pool. The SW corner of the pool kept puddling, so we dug deeper and back filled with gravel. I also put in a well pit (or whatever), but once the pipe was in, it didn’t fill with water as I expected.
I pulled the pipe today to dig deeper and you can see where the water is entering and exiting the hole!! There are also “soft” spot in the gravel bottom of the pool.
1.) What’s the proper way to put this sump well in? I used a 14” pipe, then dropped a few inches of gravel in it. Anything else? I shouldn’t drill holes in the pipe, right?
2.) As we’re compacting, mud is coming up very slowly. Is this normal? There are a few spots that almost feel like a water bed.
I’ve invested a lot of money so far and hope I can find a solution. No one in my state is available to look at this, so I’m on my own.
Drew
Drew
