Hello All,
When I purchased my house two years ago, I also got with it a ~14k gallon above ground pool that I have yet to clear up with the exception of one week where I had the water crystal clear. In the entire two years I've had the house, I've only been able to actually enjoy the pool maybe 2-3 times and have spent hundreds of dollars on chemicals that do not seem to really do much of anything. Below is the pool in its current state:
I have been to every pool store in the area and have been told that the chemical balance has been right where it needs to be and have just recommended shocking until blue or to clean my filter. I have taken this advice and currently shock the pool every 2-3 days and replaced the sand in my filter as of yesterday. I've attached two readings from two separate stores below:
Taken 7/3:
Free Chlorine: 3.02
Total Chlorine: 3.35
Combined Chlorine: .33
pH: 8.1 (when I tested at home using a dip strip and drop test I got ~7.6, so I'm not sure where they got this one.)
Hardness: 228
Alkalinity: 113
CYA: 55
Copper: .1
Iron : 0
Phosphate: 276
Taken 7/2
Free Chlorine: 7.5
Total Chlorine: 7.5
Combined Chlorine: N/A
pH: 7.4
Hardness: 250
Alkalinity: 140
CYA: 41
Copper: 0
Iron : 0
Phosphate: 300
To combat the algae, I purchased a 60% algaecide at the recommendation of the store employee and have introduced 32oz of the product around the pool. In addition to this, I also introduced ~2/3 cups of pH minus to bring the pH down (in the event that my tests are incorrect and theirs is more accurate). I'm nearing the point where I just close the pool for good and/or remove it from my house entirely, however I feel that if I gave up now, it would be a tremendous waste of the time, effort and ultimately money that I've invested in the pool. Should I shock the pool to nearly nuclear levels? Should I flock and vaccuum? should I just drain the pool entirely and start all over again? Any advice you might have on the topic would be extremely beneficial.
Thanks for your time, all!
Taken 7/3:
Free Chlorine: 3.02
Hardness: 228
Alkalinity: 113
CYA: 55
Copper: .1
Iron : 0
Phosphate: 276
Taken 7/2
Free Chlorine: 7.5
Total Chlorine: 7.5
pH: 7.4
Hardness: 250
Alkalinity: 140
CYA: 41
Copper: 0
Iron : 0
Phosphate: 300
