Any update on the heater?
At a minimum you need to have the gas line corrected, either by a licensed gas contractor or by your propane supplier. As installed it is undersized and does not meet code or pentair requirements.I think we're going to keep it for now and monitor. It only gets to 98, so we'll see how we enjoy it. Also will monitor copper levels weekly.
If you replace with similar product, the upstream blue handle valve can be closed and then turn the small screw valves can be opened to drain the backflow valve. This will prevent water freezing in it.Hey, All!
Nine months post acid wash, the pool still great. However this valve sprung a leak after a freeze. Any idea on the fix? It looks like an overly-engineered backflow valve. Can I replace with something simpler?
Thank you!
Those are backflow valves they’re pretty standard not cheap. Replace it and the next time it drain it before it’s gonna freeze.Hey, All!
Thank you!
Replace it with the same…Hey, All!
Thank you!
