I'm writing this with a red face from embarrassment. I've been trying to trace a leak in my pool for the past few days. I confirmed that the leak is in our return line (as we suspected all along). I have 1 return line, 1 skimmer, and 1 main drain in our inground pool. I turned the pump off and plugged our return line to verify that the leak was there. After leaving it for a day, our water didn't drop at all. Unfortunately, I had a severe memory lapse and forgot that the return line was plugged. I went to go turn the filter on and after a second, the pipes shook pretty bad and the spot where the PVC pipe and black polyurethane pipe (I think its polyurethane, but I'm not sure) are connected for the return line came apart. All together, the pump was on for only a couple of seconds.
I'm not entirely sure how these two pipes were connected before, but I connected them again and refastened the hose clamps around them. I'm not entirely sure I've connected them correctly, but I included pictures below. I'm sure this wasn't good for any of the pipes, filter, or pump, but is there something I should be checking or anything I should be looking out for? I'm concerned something in the filter, such as a lateral could have broken. Hopefully, at worst, I've just made the existing leak worse. I ran the pump for about a minute and didn't notice anything leaking or abnormal. I'm going to leave the pump off until tomorrow. We've been getting some rain and storms and I want everything to dry so I can monitor it.
A couple details on the pool:
- 12k gallon inground vinyl pool
- 1 return line, 1 skimmer, 1 main drain
- Hayward High Rate Sand Filter (Model: S210S)
- Hayward Super Pump (Model: sp2607x10)
