Hello friend, I found the leak, but I do not how to fix it because The hose where it is very short and I do not know whether to cut it or what to do, because it is glued with PVC and I have no idea how to remove the PVC without cutting it. can you give me some idea pleaseBest to find the leak. Most leaks are in the equipment (pump seal, o-rings, etc.). Light fittings are prone to cracking. Ozone check valves go bad. So check the equipment area thoroughly. Check for wet spots on the ground while running, then turn it off for a few days and see if it dries up, which will eliminate half of the other possibilities. But remember, the last thing they do when building one is cover the bottom in plastic, so where you see the water is not necessarily where the leak is at.
They make "fix-a-leak" products that you just pour in, but those are a temporary band-aid at best and may not work at all depending on the leak. The only guarantee is a big cleanup job after you use it.
Why do you think you have a leak?
Did you get the flo issue sorted out?
FLO Error Code and Circulation pump was extremely hot. I tracked the problem down to the motor. I thought to get a new one, then read up on capacitor replacement. The motor would get power, hum, and get extremely hot - Turns out it was a $3 capacitor replacement! Saved money, and aggravation of draining and replacing the motor.If the circ pump is buzzing and hot to the touch most likely it is the culprit. If you can remove the equipment access panels, locate the flow switch to see if it is in the closed position or even moving/fluctuating. The circ pumps are fairly expensive at about $175-250.
Good luck!
