Thanks Ump.Then either get the oasis z5 or the m400.
Oasis z5 is available from epicpoolsypply.com. There is also a $25 off coupon out there, poolreview25 (not my afffiliate, I just found it on web). M400 is in stores only but you can get it by calling Home | Marina Pool Spa & Patio and I believe they are selling it for $999. They have the 2016 model.
Both units are the same with the exception that I believe the m409 has a full filter indicator, which doesn't really matter if you are taking it on a regular basis.
These are the strongest suction units dolphin makes. The m500 just has a 3rd brush and extra timer features, but is lot more money
They scrub floor, wall, waterline. Have 4 large filters and both the mesh like echo as well as fine filter. I use the fine one since I mostly get dirt and grit in my pool. My pool has never been cleaner since using the unit. Not a speck of dirt in the pool. They have a basic remote to set either regular clean or quick clean and allow you to manually control. (You can buy the pro remote separately if you want to be able to add more features like ultra clean or waterline only) They have 3 year warranty. Swivel cord, .05 cents a hour operation. Dual drive motor. And oasis has split brushes, so it turns on a dime instead of making 3 point turns. (I prefer this because I think it misses less)
I've spoken with maytronics a couple of times and they seem to have good customer service. Was told turn around time for warranty is work is 5-7 days total door to door.
I looked into those and back thru the bots on my short list. I really want a newer model dolphin (no float handle). So I was still going with the new Triton Plus, but Amazon raised it $152. Glad they did now, as I found a couple of independant reviews that led me to the Quantum that I had ruled out for reasons I can't recall now. Both reviewers called the Quantum the best that dolphin has made. That one is under a grand and has the dual active brushes.
