Searched around and found several threads about Globrite failures and I've had my fair share. So looking to transition into Microbrites if possible.
Has anyone had luck with the niche adapter by pentair? And if so, do you have to replace them all at the same time, or can I just replace each one as they fail? Currently have two failing out of 5.
Is the transformer that was installed for the globrites typically sufficient for the microbrite? I have two Intermatic PX100 that seem to be "linked" together.
