- Aug 10, 2022
- 16
- Plaster
- Pentair Intellichlor IC-40
First time pool owner. Pool is 8 months old, ~39,000 gal and no cover. Plaster. Built in spa and slide/waterfall (use as aerator?). I have been using a "pool guy", but after I started growing algae and checking my own chemicals, I realized I am not getting what I am paying for! He says that I should have my alkalinity at or above 120 ppm? Doesn't that seem high? My chlorine is always below 1, salt generator is turned to 100% running 18 hours a day, and my salt level is 3100. pH always ends up above 8.2 a week after they are here. I'm pulling my hair out. I think I need to get a CYA level detector and start doing this all on my own. My temp has been running around 85-88 as we live in southern Utah desert. 109 F yesterday. I have the standard pH, chlorine, alkalinity measuring kit and a salt detector. What else should I get? CYA is enough? What about calcium detector? Thanks in advance!
