Oh that’s awesomeGreat! There’s also a feature where you can put in your TFP login info and it will link to your profile so the smart guys on here can see your logs when you have questions. Pretty cool.
You are lucky. Took me a month and over $1000 dollars before I figured it out. It's a racket, prove me wrong.Thanks! I already don’t like the pool store after just 1 trip!
The sold me a $1000 UV Filter. I learned here that you only need a UV filter for INDOOR POOLS!!!!!
I fixed my pool with the help here. I ripped out my puck chlorinator myself. I ripped out the UV myself. I installed a chlorinator that is automated, myself. SWG is great and it is a super solution, and you will get plenty of help here. In a short period of time, you will have control of your pool, on your terms, with very little hassle. I spend <5 minutes a day and have a crystal clear pool and I understand exactly what is going on.
Stay here and it will save you a bunch of time and money. These folks are super smart. They have no vested interest. They are a 503c. See any ads here? Nope, the people that have been saved from the pool store contribute. I took some of the 100s of $$ I saved and became a supporter. Become a TFP Supporter
It is also why you are getting so much help. I love my pool and I love TFP. I got so much benefit, I want to share what we have learned with others and give something back to TFP.
I posted a pic of the jug. Ugh it does say 31%. Last night I only saw the 20%. I’m going to buy a test kit today. My strips now say I’m finally making chlorine, the PH and alkalinity are in good range but now the CYA is low. I don’t live close to any pool stores so I want to grab everything I may need while I am there. What do you think I need on hand when I’m testing myself?Jmay905. Welcome to TFP.
It may help to start here -->ABCs of Pool Water Chemistry
Also, we recommend that you don't use pool store testing. It is inconsistent and many times inaccurate. You can read the right test kits to get here -->Test Kits Compared Evaluate them, then get one.
Also, we have Pool Math (app for your phone). You can enter all your test results and it will make specific recommendations! --> PoolMath
As for you MA addition, to give you an idea of the impact of a gallon, we need to be more specific with the MA. is it 20 degree BAUME acid...or is it 20% muriatic (I'm guessing 20%). Can you tell from the jug?
Not a big deal on the % difference. I think you’ll be just fine based on the numbers below. I would probably continue to aerate the water a bit today (run water features if you have them, or you can point returns up toward the surface so that they’d shoot out a little, or a cannonball contest helps, too…) just in case that TA number is off.I posted a pic of the jug. Ugh it does say 31%. Last night I only saw the 20%. I’m going to buy a test kit today. My strips now say I’m finally making chlorine, the PH and alkalinity are in good range but now the CYA is low. I don’t live close to any pool stores so I want to grab everything I may need while I am there. What do you think I need on hand when I’m testing myself?
Yep. I learned quickly to READ THE LABEL before buying anything...and READ THE LABEL again before putting it in your pool.I posted a pic of the jug. Ugh it does say 31%. Last night I only saw the 20%. I’m going to buy a test kit today. My strips now say I’m finally making chlorine, the PH and alkalinity are in good range but now the CYA is low. I don’t live close to any pool stores so I want to grab everything I may need while I am there. What do you think I need on hand when I’m testing myself?
Yep you all are right again the pool store sucks. I went there for a test kit and they were $20 more and honestly I don’t even think it’s the right one. I’m ordering onlineYep. I learned quickly to READ THE LABEL before buying anything...and READ THE LABEL again before putting it in your pool.
Good luck you are on your way! On the test kit, ONLY buy a TAYLOR or a TFT as you will find here --->Test Kits Compared
It is HIGHLY likely that the pool store DOES NOT have the proper test kit. If they don't have it don't buy it. Get it online. Even if it takes a few days.
Only thing I would add to your shopping list is the CYA.
Also, I wouldn't make anydrasticadds to the pool until you get a proper test kit!
Great choice. I have and have used both. Read this again before you purchase --->Test Kits ComparedYep you all are right again the pool store sucks. I went there for a test kit and they were $20 more and honestly I don’t even think it’s the right one. I’m ordering online
