- Apr 10, 2018
- 5,591
- Plaster
- CircuPool RJ-45
Question…Keep it up!
Yes. CYA shouldn't move much. No need to retest.Question…
CYA has maintained 40 for 24 hours so should I maintain SLAM FC at 16 now per the chart?
Yes lost FC last night. Water is just a little cloudy. I would say 90% clearYes. CYA shouldn't move much. No need to retest.
Water still looks cloudy? Are you still losing FC overnight?
It’s been really windy and I’ve had to clean leaves out of the skimmer every 3 or 4 hours. How much would that effect FC drop overnight as leaves accumulate?If 100% clear and still losing overnight it’s time to start hunting for hidden algae in skimmers, ladders, lights, etc.
Not much, at all, in my experience.It’s been really windy and I’ve had to clean leaves out of the skimmer every 3 or 4 hours. How much would that effect FC drop overnight as leaves accumulate?
We lost 3 FC overnight.Make sure you backwash the filter when pressure increases 25% over clean/baseline pressure.
I have scrubbed down the cleaner and when we had the water down to 50% I inspected the light. It looks recently replaced because it is sealed up tight, looks like new sealant to me. Was thinking previous owner must have replaced before we moved in last year.Did u remove the light? It’s suspect #1…
Be sure to run those water falls for a couple hours every day when the water is at slam level & maybe try to scrub them with some kinda brush.
Also inspect the bot
The 1ppm is including the margin of error. Keep it going. Failing OCLT with a clear pool usually means hidden algae. Have you scrubbed around any fixtures like returns? Checked the skimmer throat and weir door / foam on the back of it? Any main drains in the pool?Update 5th SLAM day:
Only lost 2FC overnight and pool is crystal. CC is also .5 or below.
I know the criteria for the overnight test is a loss of 1 so I guess I’ll give it one more day? Or would we call it good? Is there a margin of error?
Thanks, I’ll keep at it. Yes we have scrubbed.The 1ppm is including the margin of error. Keep it going. Failing OCLT with a clear pool usually means hidden algae. Have you scrubbed around any fixtures like returns? Checked the skimmer throat and weir door / foam on the back of it? Any main drains in the pool?
The photo above doesn’t look crystal clear to my eyes - I see the steps but not the floor of the pool beyond. Crystal clear means you can barely tell it has water in it. See:
We have a Winner! - TFP Pool of the Month (June 2022); Theme - Water Clarity
TFP members, the TFP “Pool of the Month” contest for June 2022 begins now! it’s time to show-off your pool - water clarity that is! Rules are as follows: 1. On the first of each month, a contest "theme" will be announced (i.e. water clarity, family fun, decking, custom features, lighting...www.troublefreepool.com
Try to collect some- If it’s gritty, its sand- if it poofs, its algae.So here is something else I have not asked about but this has happened since we moved in this house and still happens after the sand filter was cleaned and sand was changed. The pool company that serviced said this is normal.
In this picture I have zoomed in and you see what appears to be dirt/sand around the bottom of the pool. I never had this with my previous salt water pool with cartridge filters.
I brush this everyday and it accumulates every day all over again.
The pool company changed the sand and also installed a new MPV. This was about one year ago.
I did not think it was normal but they said it was normal to lose a little sand like this.
Also the pump really puts out some pressure so I know it is moving the water around pretty good and pushing whatever this is to the bottom and corners to accumulate.
Could this be causing me to lose FC overnight?
