I'm new to posting here on the forum but seem to be reading it whenever I have a problem so thank you all.
I'm getting tiny air bubbles sucked into my pump basket.
Equipment set-up
I have :
I have 2 skimmers that I can direct with a jandy valve.
When I turn the jandy valve one way the pressure goes down to 6 and the bubbles increase a little. When I turn it the other way the pressure drops to 5 and the pump will not come to prime.
There are no air bubbles in the returns.
There is a crackling sound in the multi-port that I can reduce/eliminate by bleeding the air in the filter.
I've had the problem for 1 year. It started when the pool was opened in 2016.
Equipment set-up
I have :
- replaced the o - ring in the pool pump
- replaced the 2 plugs in the pump
- replaced o-ring and gaskets in jandy valve.
