Hello, I am trying to troubleshoot a 19 year old control panel installed by Blue Haven pools in 2002. It has two relay switches on it. I rewired it from 2-speed to a single speed. I installed a new timer Intermatic PB913n66 and a new Temperature sensor 178T24. The panel also has a secondary timer with ten dip switches (0 delays 2 minutes from high speed to low, 1-9 delays in hours). I had it set to 0, the pool sometimes comes on and sometimes its delayed for an hour or so. Today, it shut off an hour after the set time. Is the control panel [an obsolete Ji500] at fault here. Is it time to replace the control panel?
Does anyone have a system similar to mine? If so, what have you done to understand this system? Do you know where I can download a manual for this box. I have no idea what manufacturer builds boxes for Blue Haven.
