tstack22 Member Apr 12, 2019 15 Tucson Mar 24, 2024 Add bookmark #1 Is it possible to tile over the coping and waterline on a fiberglass pool. Both are horribly stained and nothing I try removes it.
ajw22 TFP Expert Gold Supporter Silver Supporter Bronze Supporter TFP Guide Jul 21, 2013 52,926 Northern NJ Pool Size 35000 Surface Plaster Chlorine Salt Water Generator SWG Type Pentair Intellichlor IC-60 Mar 26, 2024 Add bookmark #2 I understand tiling a fiberglass pool waterline. I do not understand tiling over coping. Post pics and show us what you want to do. Waterline Tile Installation - Further Reading www.troublefreepool.com
N Newdude Mod Squad Gold Supporter Silver Supporter TFP Guide Jun 16, 2019 28,788 NY Pool Size 34000 Surface Vinyl Chlorine Salt Water Generator Mar 26, 2024 Add bookmark #3 Did you prove/remove the source of the staining? Otherwise it's just buying a little time until the new tiles are stained too.
tstack22 Member Apr 12, 2019 15 Tucson Mar 27, 2024 Add bookmark #4 Photo of the coping. The stains are just hard water I think. I want to tile since it can take more aggressive cleaning, and I could maybe add a slope to prevent ponding.
tstack22 Member Apr 12, 2019 15 Tucson Mar 27, 2024 Add bookmark #5 ajw22 said: I understand tiling a fiberglass pool waterline. I do not understand tiling over coping. Post pics and show us what you want to do. Waterline Tile Installation - Further Reading www.troublefreepool.com Click to expand... Added one above this reply. Fiberglass is somewhat fragile so there’s not a whole lot I can do to clean it. The coping also has water ponding on it.
mknauss Mod Squad TFP Expert Bronze Supporter May 3, 2014 58,525 Laughlin, NV Pool Size 6000 Surface Fiberglass Chlorine Salt Water Generator SWG Type Pentair Intellichlor IC-40 Mar 27, 2024 Add bookmark #6 That is not what is typically called 'coping'. That is the top of the fiberglass shell. Many installs cover that with real coping. Not sure what you can do now. Adding a paver or concrete coping would create a step down to your patio.
