Fiberglass pool oxidation
jackcmorgan
13
ontario
Hi,
I had a leisurescapes fiberglass pool installed two years ago. Last year when i drained the pool down for winter, the fiberglass was uniform in color above and below the waterline. This year, there is major oxidation of the fiberglass below the waterline. I am methodical with my pool levels - have the top of the line taylor testing kit, so this is not a water balance problem. I verified it isn't scale by putting some muriatic acid on the surface to no effect. What are my options here? pool fiberglass.png
Unless you wish to attempt a warranty claim with the manufacture, or pay out of pocket for a new gelcoat, you might just have to live with it. Our shell did the same. No rhyme or reason, just happens to some pools and not others even when the chemistry is properly maintained.
Reactions: jackcmorgan
