Hi Everyone,
I'm glad I found this forum thanks to a colleague! My wife and I are about to build out our first gunite pool. We currently have a vinyl pool which we plan to demo being that we're revamping our whole back yard and decided to go with a gunite version. I'm not very familiar with pool terminology, equipment specs, etc. but I've been reading throughout the forum and other sites to better understand as much as I can. To be quite honest I'm a bit overwhelmed. Below are the specs of the new build scheduled to kick into gear start April. I'll be posting progress updates as well. I would really appreciate feedback and/or recommendations from you. As far as feedback is concerned, I wouldn't mind hearing you out regarding the layout of the steps or bench as well.
Great to be here by the way! Thank You
BUILD
POOL AND SPA EQUIPMENT
BUILD
- Gunite pool 18' x 50' with a 7' x 7' spa with corner entrance, steps and bench along length of pool
- Build shell with pressurized concrete (gunite) materials Portland sand and a 10 1/2" perimeter bond beam
- Supply and install 3 water-line skimmers,
- 2" plumbing with 8" mouth color TBD
- 6 return lines,
- 2 split main drains with VGB anti entrapment plaster top drains to meet safety standards
- Install 5 SAVI 24 watt LED white pool lights and 1 SAVI 24 watt LED in spa with 300 watt transformer
- Install dry-well at designated area with connection to filter system for backwash/waste functions
- Supply and install coping treads 2" x 12" with flamed edging 136 linear feet
- Supply and install 136 linear feet of 6" x 6" water-line ceramic or porcelain tiles around pool perimeter and perimeter of spa
- Surface interior of pool with Pebble Fina quartz-based plaster
- Supply and install mechanical auto-fill box and float to be plumbed into existing outdoor spigot
- Provide plumbing from pool and spa location to designated equipment location using all 2" & 3" rigid PVC hard-pipe and sweep elbows
- Backfill all trenches
- Supply and install: Filter, heater, pump and the following equipment - plumbing with suction and return system manifolds in 2" PVC with dedicated schedule 80 Jandy Never-lube valves for each suction and return line
- Fill, prime and start pool system upon completion, including new plaster start-up procedure for maintenance for 30 days while plaster cures
- 2 Pentair intelliflow variable speed pumps and power adjustable filter pumps
- 1 Pentair triton TR-60 filter with high-rate glass filter and 2" multi-port valve for spa
- 1 Pentair triton TR-100 filter with high-rate glass filter and 2" multi-port valve for pool
- 2 Raypack RP2100, 406K BTU cupro nickle with electronic ignition, digital display heater for use with propane gas or natural gas
- 6 SAVI 24 watt white LED lights with 300 watt transformer and conduit
- 1 Jandy Aqualink RS2/10 automation system with one-touch indoor panel and I-Aqualink upgrade for web integration and smartphone/tablet app.
- 2 - 2HP Hydroletapy pumps for spa
- 1 - 2HP air blower for spa
- 1 Auto fill
