Our pool is 11 years old and hauling bleach is now a pain and getting expensive enough for me to want to upgrade to a SWG. The pool is about 16-16.5k gallons and has the EasyTouch with the wireless card for the remote. Our pool is almost 100% in the shade to the point where I am still heating it to make it comfortable enough for my wife to use. I typically keep CYA under 30 since it is so shaded and I know this may need to go up significantly if I get a new SWG and that is fine. I am not 100% dedicated to pool maintenance and with leaf drop both in the fall and spring, I end up with a green pool that is bad enough to take my CYA down to 0, but a several day SLAM is enough to get it looking fine again but requires a full DE cleaning afterwards.
I've included a picture of our equipment and our panel. I assume it makes sense to go with Pentair for the SWG since that is what I have already? Will the 40 be enough or should I go for the 60? It seems like the conventional wisdom is that with a bigger cell that is used less, you may gain a longer life. Is that correct? I am probably not going to do this job myself unless the installation costs are super excessive but if I do, where would you put the SWG? Where the tablet feeder is now is next to the heater vent and I read that putting one there is not good for the cell.
Currently, my pool runs for 2 hours at 2750 RPM, that includes an hour for the pressure side Polaris as well, and then 4 hours at 1750 rpm.
Since I will be upgrading, I think I'd like to be able to use an app to control the pool but the cost of the part itself is over $1,000. Does the upgrade do more than just remove the need for the remote? I can ask this question in the "Everything Else" if that makes more sense.
Thanks.
Thanks.
