- Apr 10, 2018
- 6,329
- Plaster
- CircuPool RJ-45 Plus
Flow rate will be determined by either your swg or your heater. For normal circulation, the goal is to run your pump at as low speed as your components will allow to save energy. In general, doubling pump speed requires 7 to 8 times more energy.
A larger swg will require the same flow rate as a smaller swg. But, a larger swg will produce more chlorine at any given time, meaning you can cut down on pump run times if you desire.
