I've done a ton of searching and haven't really found enough information to help me decide if my idea will work. Here's the deal....
I have a manual Pentair valve that allows me to control the flow of water from either the main floor drain or the skimmer. When we bought our house a month ago, the original owner had this valve set 50/50.
I have an IFCS and it seems to me that I would want all of the water being pulled from the main floor drain during the cleaning cycle. When in "Pool" mode (pump running but not the IFCS), it seems all flow should come from the skimmer rather than the main floor drain to get debris cleaned from the surface of the pool. I guess my first question is - does this make sense or should I just leave the valve at the 50/50 position all the time?
My second question (if my idea above makes sense) - can I add the Pentair Intellivalve actuator to my system and control it with my EasyTouch? If so, do I just plug a cable into the EasyTouch somewhere?
Finally, can I even add an Intellivalve actuator to my existing Pentair valve? Does it just bolt on top of the existing valve or does the existing valve need to be replaced?
Here is what it looks like:
