I’ve recently discovered the difference between stabilized and non-stabilized chlorine. Most of what’s out there is stabilized, sun protected chlorine. What’s the best kind of non-stabilized chlorine that will not raise my CYA levels?
Well I’ve recently converted from SWCG to chlorine tablets. But the chlorine I’ve been using will slowly raise my CYA. I don’t have backwash capability, so liquid chlorine or Cal hypo are my only options? I’ve already got hard water. Will this be my new problem if I use Cal Hypo?
Was tired of cleaning the thing. Calcium built up inside it. Plus this house is about to be a rental property. Trying to simplify things for tenants. Why does Cal hypo require a drain every few months? Water gets too hard?
For the fixed pumps, you'll need a timer to turn the pump on and off a few times per day. These will add about 1 oz of chlorine per minute. I run mine 3X/day for about 15 minutes each time.
I fill the tank about once per month with 10% Sodium Hypochlorite (liquid pool shock from Walmart or Home Depot). Your pool is much smaller so you may not need to run it as much.
